65inch Sony Bravia android tv
Caz31111
Hi. Does anyone no how i stop my tv from scanning channels on its own. Thank you
12 REPLIES 12
rooobb
May you be more clear on what is happening and which tv do you have?
Caz31111
If i am watching channel 3 or any channel the tv jumps through all the channel numbers then stops randomly. Thank you
Caz31111
It’s a 65inch Sony Bravia Android tv
rooobb
The dimension doesn't tell anything about your tv that has a model code you should know  what you describe with very few words is quite strange and the only think I can guess is your remote having some button blocked....
Caz31111
The only number i can think it is would be KD-65X8509C that’s the model number
Caz31111
I can be sitting watching a movie on Film4 then the tv just randomly jumps through all the television stations and stops at channel 701 for instance then iv got to turn the tv back to the channel i was watching
rooobb
Fairly old tv but it is not a thing I ever heard. Did you check the remote? Di you try to reboot the tv ?
rooobb
There could be someone who is joking with you with a wifi remote?
Caz31111
Yes iv done both i even purchased a new remote it’s definitely not that + it’s been rebooted afew times the tv is only 3/4yrs but i think at over 3grand it should last longer than that.
