About Android O
zlays84
About Android O
Hello is there any plans on updating 2017 Android Bravias to Android Oreo?
This is much better than what we have now...
https://youtu.be/AOijyUAVQTw
jumpsuit
Hi again :slight_smile:
The answer is 'Yes', however when is still unknown
currently.
12 REPLIES 12
jumpsuit
Hi @zlays84
I am just going to double check this and will get back to you
jumpsuit
currently.
zlays84
Okay cool so this is then conifirmed we are getting Android 8.0 on our TV's!
Great!
jumpsuit
Yes :slight_smile:
Support lasts a couple of years after a model's release
so the 2017 sets are definately included.
:champagne_glass:
profile.country.AT.title
Kuschelmonschter
Hero
My TV from 2016 is still on Marshmallow. Support is far from good...
Official word is that Sony will put Oreo on 2018 TVs. No word on 2017 and earlier TVs so far.
zlays84
Well that would suck if true but still can we take this confirmation kinda official...the man said YES!
jumpsuit
Hiya :slight_smile:
:grin:
Kuschelmonschter
Hero
You can find the official info here.
Sony confirmed to us at CES that it is currently working on bringing Android version 8.0, also known as Android Oreo, to its TVs. The company also said that it has shortened development time between major updates. That may be true but considering that Android 8 was released in August 2017, consumers should still arm themselves with patience in the future.
Sony confirmed that Oreo will be made available to the 2018 models but the company did not want to go into specifics about timing or the rest of the line-up yet.
Hardly anybody over at Sony knows what the actual plan is. Most of the time you get very contradicting information. Just look at the late Dolby Vision disaster. So I would take the above info by @jumpsuit with a grain of salt...
jumpsuit
@Kuschelmonschter
Can I just clarify that you are calling me a liar?
