hi, I want to get adobe flash player for my sony bravia smart TV KDL55 W808C..... any idea ?
Adobe Flashplayer is a technology that will be discontinued due to flaws in security and resources needed. Silverlight is much the same, future is HTML5 that is supported. You don't have it also on any Android smartphone, so I don't think there is any hope it will be supported on Android TV
Hi there
As Rooobb mentioned, flash is dead
However you could try sideloading Dophin Browser - which has flash built into it.
