KEGWEG
Aerial
TV KD 43x8096
Simple question
Can anyone show me where the aerial socket is on this TV as I cannot make sense od diagram
Many thanks
Kegweg
4 REPLIES 4
Peter_S.
Genius
Hi Kegweg,
Unfortunately you did not specify if it's an XE, XF, XG or XH model.
Anyway, you should find the connector around here (XH model):
Peter
KEGWEG
Thanks for reply
It is XG model, does that make a difference
To help my naivete can you tell me if it is near either side of the reverse and near the top or not
Appreciate your help
Kegweg
Peter_S.
Genius
Hi Kegweg,
If you look at the back of your TV it should be located on the lower-mid on the right side.
Peter
royabrown2
Hero
@KEGWEG
Presumably, this is the diagram you can’t make sense of:-
The input you want is the upper connector in the little block 5, labelled Cable/Antenna/External  Box.
Also described as
5. (RF input), (Satellite input)
• Connections for terrestrial/cable and
satellite.
So just about every synonym in the English language for aerial, but not ‘aerial‘ itself, the name you have been looking for 😢
