AF9- Problems to get sound from TV
profile.country.ES.title
sir_mik
Hi
I have bought this TV a month ago and I have problems to get sound from TV via ARC hdmi cable. First 15 days it works but I have restarted all the parameters and when I tried to configurate this tool sound from TV doesn´t work anymore. I have activate the HDMI CONTROL ON in A/V receiver but when I try to find the receiver with the TV Bravia sync tool, it doesn´t appear.
Has anyone this kind of problems?
Mikel
Pascale_F
Moderator
Hi Mikel,
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Win_88
Specialist
Hi there,
I'd recommend making sure the TV is up to date:
https://www.sony.co.uk/electronics/support/oled-tvs-android-a9f_af9-series/kd-55af9/downloads/000159...
If the issue remains, reset it to factory settings and try again:
https://www.sony.co.uk/electronics/support/televisions-projectors-oled-tvs-android-/kd-55af9/article...
Win_88
Murph7355
What make/mode of receiver?
I had numerous issues with mine, all now resolved (posts are up here somewhere :)).
