After update to Nougat it is not possible to update manually installed APKs or install new app from
bronzika
After Nougat update, I saw that install button is greyed out while update is started of the application that was manually installed from APK. Also, I can't install new applications via APKs.
I saw the same problem was seen on Philips Android TV and Philips acknowledged the issue and released the fix.
Is Sony aware of this issue and is there a fix?
BR//
profile.country.NL.title
Flashlab2
Yes, you still can:
On the install menu you'll see that the install button is greyed out.
Press the Action menu button on your remote.
Press it again to make the menu disappear again.
Now the Install button will work again.
7 REPLIES 7
Sean_Mc
Moderator
Hi bronzika,
Can you let me know which Sony product you are referring to?
Cheers,
Sean Mc
bronzika
Hi Sean,
Thanks for the welcome!
The model is XBR-55X850C.
BR//
batee5
Specialist
Hi bronzika,
I checked the model of your TV and it appears to be an American model so it's best to check with Sony support US or the US community pages to get more accurate info as Sony UK doesn't support installing apps from another source other than the Google Play Store.
Hope this helps.
Batee5
bronzika
Hi batee5,
my mistake... the model is KD 55X850c, bought in Croatia.
Before the update there was no problem in installing applications manually.
BR//
Almou_10
Specialist
Hi bronzik,
I think this might be related to a security update with the firmware. I guess in both cases sideloading is not recommended by Sony either before or after the update.
Cheers,
Almour_10
Flashlab2
Yes, you still can:
bronzika
Many thanks, Flashlab!
That did the trick.
I guess it is a feature and not a bug?! :slight_smile:
BR//
