Android Bravia KD49XD8305BU back and home options not working after upgrade
helper55
  1. SO
helper55
To add to my post above, I am on virgin media have tried the help option on the remote with no luck, cannot find settings like before, am I left with factory restore? Waiting for a reply from Sony.
On the left of the screen I used to have set top box and other inputs which I still have but no settings option at the bottom like before.
Bought the tv 2016
dutchice
This video shows the steps to perform a forced factory reset and a factory data reset Should you require any assistance, please visit https://www.sony.com/support
