Android TV UI Update
Bishbash99
Has anyone got the new Android TV Home Screen yet? I’m in UK nothing so far but did get a couple of app updates for core services and home.
Joe_Dohn
Specialist
What is the model of TV you're referring to and what is the issue here exactly? (slightly confused 😅)
profile.country.AT.title
Kuschelmonschter
Hero
Talking about this.
I live in Germany and I so far got the Android TV Home 3.0 update. Visuals haven't changed though. So it also seems to require some server-side switch. I even connected to U.S. servers via VPN. Didn't do the trick either.
Bishbash99
Yes is exactly that. The apps updated on my A9S but guess the server side bit from Google is yet to happen.  Was just curious to see if anyone with a Sony TV had received it as posts on other forums mentioned other OEMs getting it but nothing about Sony.
