Android TV - Youtube lip-sync is very bad?
Risc0n
Since the last couple of updates Youtube lipsync has been horrible, I mean really horrible. Some videos are fine, however I have a video you can test below that is reproducable.
Ghostbusters trailer - https://www.youtube.com/watch?v=w3ugHP-yZXw
This is direct through the TV or via my Sony 1050 AV receiver using ARC.
55X850C
Ghostbusters makes its long-awaited return, rebooted with a cast of hilarious new characters. Thirty years after the beloved original franchise took the world by storm, director Paul Feig brings his fresh take to the supernatural comedy, joined by some of the funniest actors working today - ...
Issue appears resolved in the Marshmallow update - Yippy !  :grin:
31 REPLIES 31
Hi Risc0n
I have heard many reports of this the last couple of days.  Ive edited the subject title to a more generic one, as i would like to use this thread for this issue - hope you dont mind.
For anyone else experiencing this, please click the 'me too' button on the first post.  Also it might help with the following:
  • What is your TV model
  • What firmware version
  • Has this only occured since this last update
  • Have you done a factory reset?
Risc0n
No problem @Anonymous just for reference I have done a factory reset to no avail.
Oddbin
Same issue. Reset after latest firmware update.
Issue has been present since being bought in September.
Tv model X8509 connected to ht-ct380 via HDMI Arc.
rooobb
@Risc0n I tried the video in the link on my own iMac connected to internet via a 30Mb fiber connection: it has lipsync problem, so I'm not so sure what is the problem with your tv
Risc0n
Its not just my TV, it is either a Sony issue or Youtube. Try the one below.
https://www.youtube.com/watch?v=vouZAuiMJkc
Linking the following thread to this one:
https://community.sony.co.uk/t5/televisions/kd-49x8305c-youtube-sound/td-p/2163315
I will test my YouTube again - more thoroughly this time.
rooobb
Tried this one and no evident lipsync nor on the imac nor on the TV and a BDPS5100 on this.
Risc0n
I can assure there is on mine and others. So you must have some kind of magic setup!
profile.country.SE.title
blomman00
Something is wrong, my model kdl-55w808c has this lipsync problem very often,
but never on computer, phone, tablet, other sony tv (kdl-50w805w), chromecast v2 using the same network.
I thought atleast youtube should work flawless on a android  tv...
