Android TV - Youtube lip-sync is very bad?
Risc0n
Since the last couple of updates Youtube lipsync has been horrible, I mean really horrible. Some videos are fine, however I have a video you can test below that is reproducable.
Ghostbusters trailer - https://www.youtube.com/watch?v=w3ugHP-yZXw
This is direct through the TV or via my Sony 1050 AV receiver using ARC.
55X850C
31 REPLIES 31
profile.country.AT.title
Kuschelmonschter
Hero
For me it is really hard to get hold of this issue. I have experienced it on many different occasions in different apps. It seems to be a bit of a moving target also. It might depend on different factors like the source (probably frame rate) and the amount of video post processing (e.g. motion interpolation) that is being applied.
profile.country.SE.title
blomman00
The new youtube app is much worse regarding out of sync, strange that google/sony cant fix this...
