Android youtube app cast icon not appearing
satiros123
Hello, all of a sudden my BRAVIA stopped connecting with my Android youtube app and the cast icon does not appear anymore(the one you send to TV the videos)... I tried with the same smartphone with an LG smart tv and it worked perfectly.. I have already did a factory reset to my TV, reset router, even changed the static ip of the TV, but no luck. Any ideas what to do?? Thanx
satiros123
Today I saw that the problem is fixed. Just to let you know all..cheers...
20 REPLIES 20
astmario
Same problem here!
KDL-32W705B model, firmware: PKG2.291EUA
Send to TV icon missing from YouTube app on tablet and phone.
Tried powering off tv from socket and doing same with router, no help.
Tried factory reset on TV, same thing.
Tried switching from WiFi to wired LAN, same thing.
Tried turining on DHCP instead static IP, no result.
DLNA is working, Sony SideView app is working from same tab/phone, so it is only YouTube related.
Found a workaround, but it's still not a solution, if you open YouTube app on TV, then go to settings and activate Pair device option, than from tablet/phone do the same and enter code on TV you will get Send to TV option back.
But, that way TV is identified as YouTube TV isntead of KDL.... marking, and Send To TV option is there only if YouTube app is opened on TV, if you close it TV icon is gone from tab/phone YouTube app.
profile.country.en_IE.title
Gavinf1980
Same problem here, It's really annoying as you have to open youtube on the TV to get it to work.
satiros123
Yes it is annoying, because this function was really worth it.. I also use an XPERIA Z1, so I should have full functionality with my BRAVIA.. Someone please help!!
I believe that the problem has to do with the latest update of Sony Bravia.. I hope i'm wrong
Hi all
I have reported this to Sony - hopefully they can provide some answers on this one.  Any information received will be posted back here.
astmario
So we have another topic with same problem:
http://community.sony.co.uk/t5/televisions/sony-bravia-32w795b-youtube-amp-bluetooh/td-p/1889010
Any info from Sony about this?
Hi guys
Just so that you are all aware.  Sony is aware of this issue and are currently investigating.  This problem has also been reported across other EU countries as well.
Cheers.
satiros123
astmario
What solution? There is no firmware update, so how is problem solved?
satiros123
true,the only thing that was updated was the youtube app..in the last few days i think..we can check this out,but probably it was something from youtube app side..
