Apps missing
Blondie74
Apps missing
Hi there, has the Apple TV app been added to the choices yet as I can’t see it and in search nothing?
also trying to mirror screen always says not connected to WiFi, check WiFi in settings all connected?any ideas welcome thanks
rooobb
Trying to understand what do you mean...
Apple TV has not been release till now on Android TV (assuming you have an Android TV)
The mirror screen app on the tv doesn't connect to the network, maybe is the device you are connecting to the tv that gives you that message?
