Audio passthrough (DTS-HD MA), KD-65XF9005
profile.country.FI.title
KariFIN
Hello all,
I purchased a KD-65XF9005 (XF90/X900F) unit few days ago. I also have a Yamaha RV-373 amplifier that is connected to the TV via HDMI ARC connection. Originally only the Dolby Digital passthrough from TV to the amplifier worked but after updating the firmware to 6.6520 the DTS passthrough also started to work. However, still the DTS-HD MA passthrough is not working. I also found this when googling about the issue: https://github.com/CiNcH83/bravia_atv2/issues/57.
Have  anybody else seen this issue? Additionally, is there any info on the upcoming firmware updates and whether this issue will be fixed in them?
Thank you for any info!
Br,
Kari
12 REPLIES 12
rooobb
What does it means that it is not working? in order to passthrough lossless audio to a receiver you need eARC that your tv is not supporting. Unless you refer to the compression of DTS HD MA audio that is what your link refers to
profile.country.AT.title
Kuschelmonschter
Hero
@rooobb
You should carefully read the linked bug ticket. As of Oreo, all BRAVIAs allow apps to pass DTS-HD to it, either MA or HRA. Obviously you can't pass MA over ARC. DTS-HD tracks however always embed a DTS compatible core which is what the BRAVIA extracts and passes on in case of passthrough over ARC or S/PDIF.
ricgill0
This is interesting I have a KD-65XE93005, a UBP-X800 and a Sony HT-RT5 set up with the ARC passthrough but I have never managed to get the Dolby DTS 5.1 from a blu-ray to work where Dolby Digital 5.1 always did I even made a thread about it earlier this year
https://community.sony.co.uk/t5/android-tv/sony-xe9305-5-1-surround-pass-through-help/m-p/2560949#M3...
Hopefully with the Oreo update it will now work and I can play all my blu-ray's without using a separate HDMI cable
stormyuk
Really? I have a very, very old amplifier with SPDIF and get DD 5.1 and vanilla DTS 5.1 pass through just fine, originally with my XE90 and now with the XG90. Never needed Oreo. Although I think DTS might have been broken in the past and I think it might be broken again on the latest update.
KariFIN
DTS 5.1 works for me but the DTS-HD MA (core) does not. As written above by Kuschelmonschter, the TV should pass through the DTS compatible core of DTS-HD MA but for some reason it does not work in the current firmware.
zefeer
I bought las BF the XF9005 and have if not the same a similar problem.
I have the TV connected via HDMI Arc to an Pioneer Receiver... and when i plug an HD with MKV files qith DTS HD Master i only get stereo 2.0 on the receiver... anyone know's why this happens ? Thanks
rooobb
You cannot pass through lossless audio via arc.
zefeer
OK... so should i use another HDMI port on the TV for audio ?
rooobb
Simply you can't . You should connect a player directly to an hdmi input in your ht. Or you should buy a tv with eArc
