The message you are trying to access is permanently deleted.
Hi, BBC iPlayer, ITVX and several other apps have stopped loading on my Sony Bravia Android TV. Netflix, Amazon Prime, YouTube and others work. I have performed a factory reset but this hasn’t fixed the issue. Please let know how to resolve this.
Solved! Go to Solution.
Hi @LightFoot I’ve just fixed it by uninstalling an update. Thanks for the quick reply though.
Hi @Benny23 Sorry, we cannot help you without the full model number of your TV. It will start with KD, XR or K.
Hi, @Benny23 please can you tell me how you did this? We are having the same issue. Thank you!
i have same problem..it has always worked but yesterday stopped functioning..how did you solve it?
it will not open on tv with remote control press but i can cast it from android phone no problem.
i cannot find a way of updating the app on my Bravia 75WL 50 inch tv
@langdaler @Great!!
Yeah it randomly happened to us and we tried everything. Sony wasn’t very responsive on replies so I had to do my own research. Seems like a failed update at their end. Annoying!
