BBc Iplayer
redbeard91141
BBc Iplayer
Just purchased.  Cannot find BBC IPlayer on Sony KD49XH9505
Tags (1)
2 ACCEPTED SOLUTIONS
redbeard91141
Hi
Thanks for a prompt response
I found it in Sony Select.  Many thanks.
Do know if Amazon Music is available for this TV.
I find the lack of documentation with the TV annoying.
Brian
Tonycv51
Don't think it is.  And don't think you can cast to it either from amazon music.
  • I assume the app is too locked down to sideload but worth a Google in case someone got it to wirk
5 REPLIES 5
Peter_S.
Genius
Have you checked if it's available in the Google Play Store?
Peter
Tonycv51
Assume its in Sony select
redbeard91141
Hi
I will look in Google Play Store.
Brian
redbeard91141
Hi
Brian
Tonycv51
