Best IPTV app
twh1948
Best IPTV app
Can anyone tell me the best iptv app for Sony tv, all my mates use smart iptv (ssiptv) will this work on Sony? if this can be used all I have to do is send the app mac address to a provider and that's it restart the app and away it goes.
7 REPLIES 7
The_Black_Rose
Specialist
Hi twh1948,
Could you let us know of the model number of your TV?
Cheers,
The_Black_Rose
twh1948
Sony Baravia kd43x8005bu
@The_Black_Rose wrote:
Hi twh1948,
Cheers,
The_Black_Rose
KD43XE8005BU
profile.country.NL.title
hija31
It's Android TV , so yes it will work.
I have it installed on on my XD8599 model.
twh1948
Great thanks for the answer.
Gall77
I’m trying to find the smart iptv app in the google play store but can’t find it. Can anybody help.
twh1948
Goole have taken it out. Download it from the offiicial website.
https://siptv.eu/news/
Also instructions here,
https://www.teamandroid.com/2018/08/01/install-apk-files-sideload-apps-android-tv/
Then put it onto a usb memory stick and install it onto your tv. It's .apk file.
gmemran
hello,
you can follow their guide. it's can be helpful : iptv smarter pro apk
