Bravia firmware update May 2019
barneymcgrew
I have 2 Bravia models and use these to watch video content streamed from my WD Mycloud. in the last 2 days both TVs have ceased to recognise the video content on the Mycloud. Both TVs have good wifi connectivity and the Mycloud works perfectly fine thru Ipads. PC and mobile phone.
I am starting to suspect there may have been an update that has changed the way the devices content works. Can anyone confirm if they are having similar problems. First noticed around 29/30th May.
barneymcgrew
yes, factory reset carried out on both Bravia TVs confirms that ‘no content
available’ on my server. Even though the music titles are visible the
content is not. I know the server is ok as I can access all content on
ipad/pc.
Looks like Sony have introduced Digital Rights Management restrictions on a
firmware update.
Can you confirm that this is the case please so I can stop wasting my time
trying to fix it.
thx
4 REPLIES 4
Hi there,
Have you tried a factory reset?
Best wishes,
M
barneymcgrew
ipad/pc.
firmware update.
trying to fix it.
thx
The_Black_Rose
Specialist
Hi barneymcgrew,
What are the model number of the TVs ?
Cheers,
The_Black_Rose
barneymcgrew
problem resolved.
NAS drive database rebuild. Directory corrupted.
TVs not to blame
