Bravia XBR55850D
Sugarfeet
Bravia XBR55850D
Somehow restricted profile got set upand I have no idea what the password is found several fixes but none worked.  I need to perform a factory reset but cannot unless restricted profile is disabled.     Is there a master password that gives me access or a workaround.
Pascale_F
Moderator
Hi  Sugarfeet,
Welcome to the community. The Sony website is experiencing some technical issues at the moment and I'm having trouble finding the manual page for your TV.
Please try searching the Q&As and the manual for your TV via the Sony website for 'restricted profile'. If no luck,
just call Sony Support  on Wednesday morning.
Thanks,
Pascale_F
