BUG: Android 6.0.1 reboots after enabling VPN apps
Jecht_Sin
Enthusiast
I have installed via USB and tested Block This (open source) and Adguard (not together. One per time) on my KD49XD8099 with Android 6.0.1 and they simply worked great! No more annoying ads (yes, I know. Companies don't like it, especially Google, but they are perfectly legal. Also we are allowed by Android itself to install whatever we like).
The only problem is that after turning the TV off (standby) few hours, when I turn it on the television starts rebooting. Uninstalling them the television (and rebooting just in case) Android becomes "stable" again (quoted because I've got reboots even without tampering with special apps). The apps were set to enable the VPN at boot. Not that it should matter, since the reboot happens just putting the tv in standby.
Now, I do understand that an external app, not made specifically for Android TV may not work (but as I wrote they actually do the job they are made for), but if the television/Android reboots there is a (very critical) issue with the OS, not the app. To test the issue the developers just need to install the apps mentioned (again, enabling the VPN at boot).
148 REPLIES 148
Luigi_R
Hey guys, I have got couple of days ago an update of the system but the issue is still there. Is Sony working in it?. Is there a bug tracker?
Michelasso
I am afraid our best chance is to wait for Android 7. Sony/Mediatek don't seem to do many bug fixing. All major bugs I had before the last update v6.1004 are still there.
Luigi_R
Thanks for replying but It is a very annoying bug.How it is possible that no one takes action. I see here bugs related to Amazon and stupid things like that but not this one which leads to a crash of the tv several time a day if the wifi connection is not stable.
PS: by mistake I have terminated the system app streaming channel and I'm not able anymore to restart it. Do you know to do it?
Luigi_R
[quote=Quinnicus]Unfortuantely this cannot be listed as a bug[/quote]
If the crash is not caused by the app/s then Sony should care about it since the bug is in the product sold by them. I have tested both Wifi and Ethernet connection and both make the tv rebooting if the tv goes in standby with an active VPN connection.
I will not buy a new router with a VPN support just to workaround a bug in your product.
PS: OpenVPN is in a google play store and it work well on any other android devices
I will buy a new router with a VPN support just to workaround a bug in your product.
The simple fact is that this is not a bug under Sony's Control.
I know that you will disagree on this :slight_smile:
Although having a router than supports OpenVPN protocols is a good work-around.  I have the Asus DSL-AC68U which can do this.
Luigi_R
Quinnicus thanks for replying. I will certainly blame the app if it would be the only one causing the crash but since several apps using the VPN service have similar behavior then I will blame the network manager and/or the os.
As a user, to whom should I report the bug? I bought the TV from Sony then I believe Sony should forward the request to the responsible parties.
Hi there
If its a problem with the app and in this case associated apps that crash when using the OpenVPN app, then my first port of call would be the app developer themselves.  I understand this OpenVPN app is available on the Google Play Store on the TV - but I am wondering if it was more developed for the Nvidia Shield instead of an actual TV?
Ok, in simplistic terms:
  • Hardware Issue with the TV - Sony
  • Software (OS) issue - Sony
  • Software (Built in apps) - Sony and/or App developer (i.e. Netflix, iPlayer, Amazon etc)
  • Software (External apps) - App developer
Jecht_Sin
Enthusiast
Indeed, @Anonymous, this is a critical OS issue. An user app, as it is any app from the Play Store, should never cause the OS (or even worse the kernel!) to reboot. Ever.
This is a Denial of Service issue the least, a kernel panic the worst. The userspace doesn't have any permission to kill/restart the whole OS. If that happens it's because an API, called by the user apps (in this case ralated to the VPN) is affected by a very critical, serious bug. And that bug, being in the OS, has been introduced by Sony or Mediatek, so it is a MUST for them to fix it.
Just to give an idea, think if any of the hundreds, if not thousands of users of a super computer had the ability to make the whole system rebooting, just with a bug in their apps. Millions of dollars in service disruption thrown in the toilet. In a much smaller scale this is the same identical concept.
devindran
I'm having the same issue as well. Tested on VyprVPN and Torguard. Both forces a reboot if I standby while connected.
Luigi_R
The crash seems to come from a mediatek library. I will ask Arne Schwabe, developer of OpenVPN apk to test the app on another AndroidTV (Panasonic or Philips for instance) based on adroid 6. This is the log file from start till the crash:
05-09 22:29:47.184  8623  8623 D com.sony.dtv.demomode.receiver.ScreenStateReceiver: DemoMode receives ACTION_SCREEN_ON intent when AC Off/On
05-09 22:29:47.188  8623  8623 D MtkTvSpecialMode: New class MtkTvSpecialMode
05-09 22:29:47.188  8623  8623 I TVNative: Load libcom_mediatek_twoworlds_tv_jni.so start !
05-09 22:29:47.189  8633  8645 D QuickSetupMgrContentProvider: query()
05-09 22:29:47.194  2915  2990 D ExternalInputProvider: query
05-09 22:29:47.194  2915  2990 D ExternalInputProvider: queryInputDetection
05-09 22:29:47.198  4531  8869 I SonyDTVBrowser_CEB: receive broadcastintent PRE_SCREEN_ON
05-09 22:29:47.199  2915  3524 D ExternalInputProvider: query
05-09 22:29:47.210  4531  4531 I SonyDTVBrowser_CEB: onDestroy
05-09 22:29:47.212  2915  3606 D ExternalInputProvider: query
05-09 22:29:47.212  2915  3606 D ExternalInputProvider: queryInputDetection
05-09 22:29:47.216  2915  2938 D ExternalInputProvider: query
05-09 22:29:47.221  2915  2990 D ExternalInputProvider: query
05-09 22:29:47.221  2915  2990 D ExternalInputProvider: queryInputDetection
05-09 22:29:47.226  2915  3606 D ExternalInputProvider: query
--------- beginning of crash
05-09 22:29:47.228  1208  1208 F DEBUG   : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
05-09 22:29:47.228  1208  1208 F DEBUG   : Build fingerprint: 'Sony/BRAVIA_ATV2_EU/BRAVIA_ATV2:6.0.1/MMB29V.S66/1.6.0.10.04.1.00:user/release-keys'
05-09 22:29:47.228  1208  1208 F DEBUG   : Revision: '0'
05-09 22:29:47.228  1208  1208 F DEBUG   : ABI: 'arm'
05-09 22:29:47.228  1208  1208 F DEBUG   : pid: 1775, tid: 1936, name: navigator  >>> /basic/dtv_svc <<<
05-09 22:29:47.229  1208  1208 F DEBUG   : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x0
05-09 22:29:47.231  1716  2546 W NativeCrashListener: Couldn't find ProcessRecord for pid 1775
05-09 22:29:47.231  2915  3524 D ExternalInputProvider: query
05-09 22:29:47.231  2915  3524 D ExternalInputProvider: queryInputDetection
05-09 22:29:47.237  2915  2932 D ExternalInputProvider: query
05-09 22:29:47.242  2915  3606 D ExternalInputProvider: query
05-09 22:29:47.242  2915  3606 D ExternalInputProvider: queryInputDetection
05-09 22:29:47.261  1208  1208 F DEBUG   :     r0 00000000  r1 78d75230  r2 00000004  r3 00000011
05-09 22:29:47.261  1208  1208 E DEBUG   : AM write failed: Broken pipe
05-09 22:29:47.261  1208  1208 F DEBUG   :     r4 7713eeec  r5 00000000  r6 b3e21afc  r7 00000002
05-09 22:29:47.261  1208  1208 F DEBUG   :     r8 7a6f8948  r9 7a6f88d8  sl ffffffff  fp 7a6f88ac
05-09 22:29:47.261  1208  1208 F DEBUG   :     ip 00000000  sp 7a6f8828  lr b28963ac  pc b5ca2bd0  cpsr 200f0010
05-09 22:29:47.306  1208  1208 F DEBUG   :
05-09 22:29:47.306  1208  1208 F DEBUG   : backtrace:
05-09 22:29:47.306  1208  1208 F DEBUG   :     #00 pc 000bbbd0  /linux_rootfs/basic/libdtv_common.so (_net_get_dev_ip+176)
05-09 22:29:47.306  1208  1208 F DEBUG   :     #01 pc 000c2ae8  /linux_rootfs/basic/libdtv_common.so
05-09 22:29:47.306  1208  1208 F DEBUG   :     #02 pc 000ca200  /linux_rootfs/basic/libdtv_common.so (x_dhcpc_get_info+68)
05-09 22:29:47.306  1208  1208 F DEBUG   :     #03 pc 0024f768  /linux_rootfs/basic/libmtkapp.so (a_nw_get_crnt_real_ip_info+1148)
05-09 22:29:47.306  1208  1208 F DEBUG   :     #04 pc 00ad1a60  /linux_rootfs/basic/libmtkapp.so
05-09 22:29:47.306  1208  1208 F DEBUG   :     #05 pc 002df2b4  /linux_rootfs/basic/libmtkapp.so (nav_brdcst_msg_to_components+296)
05-09 22:29:47.306  1208  1208 F DEBUG   :     #06 pc 002e79e0  /linux_rootfs/basic/libmtkapp.so
05-09 22:29:47.306  1208  1208 F DEBUG   :     #07 pc 00030758  /linux_rootfs/basic/libdtv_common.so
05-09 22:29:47.306  1208  1208 F DEBUG   :     #08 pc 0002fb14  /linux_rootfs/basic/libdtv_common.so
05-09 22:29:47.306  1208  1208 F DEBUG   :     #09 pc 0001759c  /linux_rootfs/basic/libdtv_osai.so (thread_main+76)
05-09 22:29:47.306  1208  1208 F DEBUG   :     #10 pc 0000bdd0  /linux_rootfs/basic/libdtv_osai.so (os_drv_thread_main+96)
05-09 22:29:47.307  1208  1208 F DEBUG   :     #11 pc 00006e80  /linux_rootfs/lib/libpthread-2.18.so
05-09 22:29:47.307  1208  1208 F DEBUG   :     #12 pc 000ccd7c  /linux_rootfs/lib/libc-2.18.so
05-09 22:29:47.329  8623  8623 D MTKAPI  : dtv_svc rpc server confirmed ready.
05-09 22:29:47.338  8623  8623 W libc    : pthread_create sched_setscheduler call failed: Operation not permitted
05-09 22:29:47.339  8623  8623 D MTK_MW  : c_rpc_reg_mtktvapi_audioinfo_cb_hndlrs <rw_mtktvapi_audioinfo.c: 145>
05-09 22:29:47.339  8623  8623 D MTK_MW  : c_rpc_reg_mtktvapi_rating_cb_hndlrs <rw_mtktvapi_rating.c: 443>
05-09 22:29:47.339  8623  8623 D MTK_MW  : ####CH LOGO  c_rpc_reg_mtktvapi_ch_logo_cb_hndlrs <rw_mtktvapi_df_mngr.c: 166>
05-09 22:29:47.340  8623  8623 D MTKAPI  : mtal init result = 0
05-09 22:29:47.340  8623  8623 D MTKAPI  : !!!!!!! JNI_OnLoad OK !!!!!!
05-09 22:29:47.340  8623  8623 I TVNative: Load libcom_mediatek_twoworlds_tv_jni.so OK !
05-09 22:29:47.401  1208  1208 W debuggerd: type=1400 audit(0.0:33): avc: denied { read } for name="rmmgr" dev="dm-1" ino=692 scontext=u:r:debuggerd:s0 tcontext=u:object_r:rmmgr_device:s0 tclass=chr_file permissive=0
05-09 22:29:47.412  1716  2465 D WindowManager: KEYCODE_POWER: event.getDeviceId=5, down=false
05-09 22:29:47.416  1208  1208 W debuggerd: type=1400 audit(0.0:34): avc: denied { search } for name="graphics" dev="tmpfs" ino=3060 scontext=u:r:debuggerd:s0 tcontext=u:object_r:graphics_device:s0 tclass=dir permissive=0
05-09 22:29:47.492  2618  2636 V com.sony.dtv.braviasyncservice.utilities: ExternalModuleAccessor.onControlStateChanged() enabled -> true
05-09 22:29:47.492  2618  2636 D com.sony.dtv.braviasyncservice.utilities: ExternalModuleAccessorService changed to isEnabled = true reason = Service wakeup
05-09 22:29:47.493  2618  2636 D com.sony.dtv.braviasyncservice.utilities: ModelInfoWrapper()
05-09 22:29:47.493  2618  2636 I com.sony.dtv.braviasyncservice.utilities: ModelInfoWrapper.checkDestination:DVB_AEP_T2S2
05-09 22:29:47.493  2618  2636 I com.sony.dtv.braviasyncservice.utilities: ModelInfoWrapper.getDestination:14
05-09 22:29:47.493  1716  2504 I HdmiCecController: [S]:<Report Physical Address> src: 0, dst: 15, params: 00 00 00
05-09 22:29:47.494  1716  1716 W HdmiCecLocalDeviceTv: Preferred addres will not be stored for TV
05-09 22:29:47.667  1716  2504 I HdmiCecController: [S]:<Device Vendor Id> src: 0, dst: 15, params: 08 00 46
05-09 22:29:47.837  1716  2504 I HdmiCecController: [S]:<Active Source> src: 0, dst: 15, params: 00 00
05-09 22:29:47.976  1208  1208 W debuggerd: type=1400 audit(0.0:35): avc: denied { read } for name="fusion.0.4" dev="tmpfs" ino=6834 scontext=u:r:debuggerd:s0 tcontext=u:object_r:mt_dtv-svc_tmpfs:s0 tclass=file permissive=0
05-09 22:29:49.146  1716  1716 V NotificationService: pkg=de.blinkt.openvpn canInterrupt=false intercept=true
05-09 22:29:49.152  1716  1716 V NotificationService: pkg=de.blinkt.openvpn canInterrupt=false intercept=true
05-09 22:29:49.228  1208  1208 F DEBUG   :
05-09 22:29:49.228  1208  1208 F DEBUG   : Tombstone written to: /data/tombstones/tombstone_09
05-09 22:29:49.252  1716  1736 I BootReceiver: Copying /data/tombstones/tombstone_09 to DropBox (SYSTEM_TOMBSTONE)
05-09 22:29:49.281  8623  8623 D com.sony.dtv.demomode.utils.MtkUtils: isPictureResetModeOff
05-09 22:29:49.300  8623  8623 V com.sony.dtv.demomode.usb.UsbUtils: USBFunction: Auto check function from devices
05-09 22:29:49.301  8623  8623 V com.sony.dtv.demomode.usb.UsbUtils: RuntimePermission: Storage have not granted yet!
05-09 22:29:49.301  8623  8623 D com.sony.dtv.demomode.utils.ShopDemoDataManager: update usbRootPath:null
05-09 22:29:49.301  8623  8623 V com.sony.dtv.demomode.usb.UsbUtils: USBFunction: Set usbFunctionPath=
05-09 22:29:49.301  8623  8623 V com.sony.dtv.demomode.provider.DemoDataUpdater: delete begin
05-09 22:29:49.303  8623  8623 V com.sony.dtv.demomode.utils.ShopDemoDataManager: ACTION_DEMODATA_UNAVAILABLE is sent
05-09 22:29:49.306  8623  8623 D com.sony.dtv.demomode.powerstate.OffRsControlService: onCreate() called
05-09 22:29:49.307  8623  8623 I com.sony.dtv.demomode.powerstate.OffRsControlService: [onStartCommand]: segment=QHL
05-09 22:29:49.307  8623  8623 E com.sony.dtv.demomode.powerstate.OffRsControlService: [onStartCommand]: unsupported segment
05-09 22:29:49.312  8623  8623 D com.sony.dtv.demomode.powerstate.OffRsControlService: onDestroy() called
05-09 22:29:49.317  4980  8875 I DiscoveryApplication: com.sony.dtv.discovery is build-in plugin
05-09 22:29:49.321  8725  8725 I Receiver: Intent { act=com.sony.dtv.demomode.intent.action.DEMODATA_UNAVAILABLE flg=0x10 cmp=com.sony.dtv.sonyshelf/.Receiver }
05-09 22:29:49.325  3064  3064 D IdleTvStandByReceiver: ACTION_PRE_SCREEN_ON received
05-09 22:29:49.327  4980  8875 I PriorityItemListClient: load priority list (shouldRefresh:false forceRefresh:true)
05-09 22:29:49.335  8725  8877 I Invoker : Received action is com.sony.dtv.demomode.intent.action.DEMODATA_UNAVAILABLE !
05-09 22:29:49.344  1716  2594 I ActivityManager: Start proc 8878:com.sony.dtv.enclave.service/u0a6 for content provider com.sony.dtv.enclave.service/.ConfigProvider
05-09 22:29:49.393  8878  8878 W System  : ClassLoader referenced unknown path: /system/priv-app/CAL/lib/arm
05-09 22:29:49.405  8878  8878 I EnclaveApplication: onCreate() enter
05-09 22:29:49.407  8878  8878 I EnclaveApplication: Connect to CidUtilService request enter
05-09 22:29:49.415  8878  8878 I EnclaveApplication: isServiceProcess() returns false
05-09 22:29:49.416  8878  8878 I EnclaveApplication: onConnected enter
05-09 22:29:49.419  8878  8889 I ConfigProvider: query()
05-09 22:29:49.419  8878  8878 I EnclaveApplication: mCidService.getCid() bytes length[32]
05-09 22:29:49.420  8878  8878 I UpdateConfigTask: [SetConfig][loadable:true][Did:64]
05-09 22:29:49.433  8878  8892 I UpdateConfigTask: [CurrentConfig][loadable:true][Did:64]
05-09 22:29:49.436  4829  8876 E WhAwareAppOpsCompat: Couldn't initialize instant apps metadata client! Disabling instant apps.
05-09 22:29:49.442  3712  5245 I ECBinderJava: line=100 onTransact() func_name component
05-09 22:29:49.444  3712  3722 I ECBinderJava: line=100 onTransact() func_name component
05-09 22:29:49.708  1232  1308 I GRM     : Pid(1775) died, will release its resources!!
05-09 22:29:49.708  1232  1308 I GRM     : ============================Start==============================
05-09 22:29:49.708  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.708  1232  1308 I GRM     : Resource List-->>>>
05-09 22:29:49.708  1232  1308 I GRM     : Resource List--<<<<
05-09 22:29:49.708  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.708  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709  1232  1308 I GRM     : Resource List--<<<<
05-09 22:29:49.709  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709  1232  1308 I GRM     : Resource List-->>>>
05-09 22:29:49.709  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tuner0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.709  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tuner1_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_user_define_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710  1232  1308 I GRM     : Resource List-->>>>
05-09 22:29:49.710  1232  1308 I GRM     : Resource List--<<<<
05-09 22:29:49.710  1232  1308 I GRM     : Componet Name:mheg5_RM_ctrl, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710  1232  1308 I GRM     : Component Count: 12
05-09 22:29:49.710  1232  1308 I GRM     : =============================End===============================
05-09 22:29:49.710  1232  1308 I GRM     : MtkRmServiceDestoryComponent(1651) destory component:mheg5_RM_ctrl
05-09 22:29:49.710  1232  1308 I GRM     : ============================Start==============================
05-09 22:29:49.710  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.710  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711  1232  1308 I GRM     : Resource List-->>>>
05-09 22:29:49.711  1232  1308 I GRM     : Resource List--<<<<
05-09 22:29:49.711  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tuner0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tuner1_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_user_define_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:49.711  1232  1308 I GRM     : Component Count: 11
05-09 22:29:49.711  1232  1308 I GRM     : =============================End===============================
05-09 22:29:49.711  1232  1308 I GRM     : MtkRmServiceDestoryComponent(1714) return
05-09 22:29:49.897  1716  1716 V DeviceDiscoveryAction: No device is detected.
05-09 22:29:49.897  1716  1716 V DeviceDiscoveryAction: ---------Wrap up Device Discovery:[0]---------
05-09 22:29:49.897  1716  1716 V DeviceDiscoveryAction: --------------------------------------------
05-09 22:29:49.897  1716  1716 V HotPlugDetectionAction: Hot-plug dection started.
05-09 22:29:50.712  1232  1308 I GRM     : Pid(1775) died, will release its resources!!
05-09 22:29:50.712  1232  1308 I GRM     : ============================Start==============================
05-09 22:29:50.712  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.712  1232  1308 I GRM     : Resource List-->>>>
05-09 22:29:50.712  1232  1308 I GRM     : Resource List--<<<<
05-09 22:29:50.712  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.712  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.712  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.712  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713  1232  1308 I GRM     : Resource List-->>>>
05-09 22:29:50.713  1232  1308 I GRM     : Resource List--<<<<
05-09 22:29:50.713  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tuner0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tuner1_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_user_define_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.713  1232  1308 I GRM     : Component Count: 11
05-09 22:29:50.713  1232  1308 I GRM     : =============================End===============================
05-09 22:29:50.713  1232  1308 I GRM     : MtkRmServiceDestoryComponent(1651) destory component:svctx_RM_ctrl_user_define_share
05-09 22:29:50.713  1232  1308 I GRM     : ============================Start==============================
05-09 22:29:50.713  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714  1232  1308 I GRM     : Resource List-->>>>
05-09 22:29:50.714  1232  1308 I GRM     : Resource List--<<<<
05-09 22:29:50.714  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.714  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tuner0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.715  1232  1308 I GRM     : Resource List-->>>>
05-09 22:29:50.715  1232  1308 I GRM     : Resource List--<<<<
05-09 22:29:50.715  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tuner1_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:50.715  1232  1308 I GRM     : Component Count: 10
05-09 22:29:50.715  1232  1308 I GRM     : =============================End===============================
05-09 22:29:50.715  1232  1308 I GRM     : MtkRmServiceDestoryComponent(1714) return
05-09 22:29:50.900  4980  4980 I SPEgetPriorityListCmd: priority list received: 10 items
05-09 22:29:50.900  4980  4980 I PriorityItemListClient: onReceive (the size of priorities : 10)
05-09 22:29:50.900  4980  4980 I DynamicItem: [pos:1]
05-09 22:29:50.900  4980  4980 I DynamicItem: [pos:2]
05-09 22:29:50.900  4980  4980 I DynamicItem: [pos:3]
05-09 22:29:50.900  4980  4980 I DynamicItem: [pos:4]
05-09 22:29:50.900  4980  4980 I DynamicItem: [pos:5]
05-09 22:29:50.901  4980  4980 I DynamicItem: [pos:6]
05-09 22:29:50.901  4980  4980 I DynamicItem: [pos:8]
05-09 22:29:50.901  4980  4980 I DynamicItem: [pos:9]
05-09 22:29:50.901  4980  4980 I DynamicItem: [pos:10]
05-09 22:29:50.901  4980  4980 I DynamicItem: [pos:12]
05-09 22:29:50.901  4980  4980 I PriorityListDataHelper: [pos:1] type:dynamic
05-09 22:29:50.901  4980  4980 I PriorityListDataHelper: [pos:2] type:dynamic
05-09 22:29:50.901  4980  4980 I PriorityListDataHelper: [pos:3] type:dynamic
05-09 22:29:50.901  4980  4980 I PriorityListDataHelper: [pos:4] type:dynamic
05-09 22:29:50.901  4980  4980 I PriorityListDataHelper: [pos:5] type:dynamic
05-09 22:29:50.902  4980  4980 I PriorityListDataHelper: [pos:6] type:dynamic
05-09 22:29:50.902  4980  4980 I PriorityListDataHelper: [pos:8] type:dynamic
05-09 22:29:50.902  4980  4980 I PriorityListDataHelper: [pos:9] type:dynamic
05-09 22:29:50.902  4980  4980 I PriorityListDataHelper: [pos:10] type:dynamic
05-09 22:29:50.902  4980  4980 I PriorityListDataHelper: [pos:12] type:dynamic
05-09 22:29:50.902  4980  4980 I PriorityListDataHelper: save item size:10
05-09 22:29:50.902  4980  4980 I PriorityListProvider: onListUpdated list size:10
05-09 22:29:51.230  1716  1716 V NotificationService: pkg=de.blinkt.openvpn canInterrupt=false intercept=true
05-09 22:29:51.236  1716  1716 V NotificationService: pkg=de.blinkt.openvpn canInterrupt=false intercept=true
05-09 22:29:51.313  8623  8899 V com.sony.dtv.demomode.provider.DemoDataUpdater: update start path=null
05-09 22:29:51.314  8623  8899 V com.sony.dtv.demomode.provider.DemoDataProvider: delete uri=content://com.sony.dtv.demomode.provider.demodata/
05-09 22:29:51.314  8623  8899 D com.sony.dtv.demomode.provider.DemoDataManager: clear
05-09 22:29:51.327  8623  8899 V com.sony.dtv.demomode.provider.DemoDataUpdater: delete End
05-09 22:29:51.715  1232  1308 I GRM     : Pid(1775) died, will release its resources!!
05-09 22:29:51.715  1232  1308 I GRM     : ============================Start==============================
05-09 22:29:51.715  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_main, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.715  1232  1308 I GRM     : Resource List-->>>>
05-09 22:29:51.715  1232  1308 I GRM     : Resource List--<<<<
05-09 22:29:51.715  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_sub, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.715  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_thrd, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_rec, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716  1232  1308 I GRM     : Resource List-->>>>
05-09 22:29:51.716  1232  1308 I GRM     : Resource List--<<<<
05-09 22:29:51.716  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_rec2, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tvbypass, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_vdec0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_dmx_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tuner0_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716  1232  1308 I GRM     : Componet Name:svctx_RM_ctrl_tuner1_share, Pid:1775, priority:100, preempt:TRUE, fg:FALSE.
05-09 22:29:51.716  1232  1308 I GRM     : Component Count: 10
05-09 22:29:51.716  1232  1308 I GRM     : =============================End===============================
