Hey! Can any kind person help me? My TV model is KDL-46EX710. I will use the CA module with a TV subscription from Boxer. I only get some of the channels. According to the support it is because my TV has a limit on reception on DVB-T2. Is this really possible? Do I have to buy a new TV then? Best regards P.K.Hey! Can any kind person help me? My TV model is KDL-46EX710. I will use the CA module with a TV subscribtion from Boxer. I only get some of the channels. According to the support it is because my TV has a limit on reception on DVB-T2. Is this really possible? Do I have to buy new TV then? Best Regards/ Viktoria
Hey swedenrockare, the TV actually only supports DTV, for the CAM that's totally up to the provider to tell you what does it support. If that's what they said, a new TV is the answer.
