can't see the BBC iPlayer, All 4, ITV etc on the HOME SCREEN
apanveka
Hi all,
I have just bought the 65 ZD9. As it is too too slow, so I have decided to follow some of the videos on Youtube to speed up the TV.
In the process I have Force Stopped "Sony Select" and now I can't see the BBC iPlayer, All 4, ITV etc on the HOME SCREEN.
Is there any way to re-enable the Sony Select so I can see the missing apps on the HOME SCREEN again, please?
Thanks for your help.
stormyuk
Do a google search for "hoshsadiq" "github" and "bravia-youview-player-launchers" and install the APK there (you will need to put in on an external USB drive, and install one of the file mangers from the Android TV store to access it), you can even disable Youview. This will then add the players to the home screen.
stormyuk
apanveka
@stormyuk : you are star mate.
