Can you use the RMF-TX600E remote for the KD-75ZF9 TV
Gadger_Snr
Can you use the RMF-TX600E remote for the KD-75ZF9 TV, I know its for the newer  XG95 range. Thank you
EdwinaU
Moderator
Hi Gadger_Snr,
The standard IR remote and the Touchpad remote are compatible for Android TVs in the EU region. You can find out more here.
If you need one, the remote model for your TV (RMF-TX220E) can be found here.
Best wishes,
Ed
jukbee
I was in the similar situation like you. And my findings should be applied to yours!
(Copy and Paste from my post)
Ok, I took a plunge and bought AG9's remote control (RMF-TX600E) to use with my AF9 tv and here is my finding.
One missing button is APPS, which is to open the app drawer.
When in IR mode (right after putting AAA batteries in, without bluetooth pairing), all buttons are working, EXCEPT Voice Command button. Button Mapper app can be used to customise most of the buttons except Voice Command button.
After BT pairing, these buttons are not working;-
Info,
Menu (green button under 9),
Colour buttons,
Google Play,
Netflix,
Rec List,
Source Selection,
Action Menu (clock wheel),
Previous channel,
Audio,
Subtitle,
Help.
Voice Command is responded when pressed but doesn't take in command. I tried using Button Mapper app to map those keys but to no avail. It's as if the Button Mapper app can't customise buttons in BT mode.
However, remote control in BT mode is noticeably snappier than in IR.
Hope this info is useful. Please feel free to share your tips and advice if you know something that I haven't covered here.
Thanks!
Gadger_Snr
Thank you for the information, much appreciated Andrew
Might make me re-think.
