Cant watch the Disney + (X90J) though it has been installed
andywkchoi
I cant watch Disney + even though I got the app.  .
The screen just shows " Disney has a new update. Please update the app by visiting the store.
My TV is X90J google TV
Please help how to update the app.   Thanks
6 REPLIES 6
Marino.Manolo
Genius
First try a restart of Android TV, press and hold Power / OFF on the Remote ...
It could also be a network problem, are other applications working fine?
andywkchoi
Thank for your reply.
I tired but still in vain.  The verison shown in the TV is out update but I cant do the update.
Do you know how to do the update manually ?
Andy
Marino.Manolo
Genius
If you can, uninstall the App and then install it again.
andywkchoi
I dont know there is no button for uninstalling Disney+ app but other apps does. It looks very strange.
Marino.Manolo
Genius
It is therefore an App considered to be a System, it cannot be uninstalled.
Check if at least it is allowed to clear the cache memory ...
HannahEd01
Community Team
Hey andywkchoi, you do the updates from Google Play Store, you need to have a Google account and to login to it then find the app and update it. Or from settings on the Home menu, then apps, find Disney + then click on it and click update.
