Casting Apple TV to Sony TV KD-32800
profile.country.IE.title
Ruth-RSP
Any ideas on how to cast Apple TV or otherwise use Apple TV on Sony Bravia KD-32800 32 in tv? Can’t see how to do! Thanks
6 REPLIES 6
LightFoot
Specialist
Hi @Ruth-RSP   To cash Apple you need AirPlay 2. Have a look at your TVs specifications,  if it does not say Apple Homekit - Yes, then you are out of luck.
royabrown2
Hero
LightFoot
Specialist
Ruth-RSP
Hi, yes, thanks - sadly, I should have done my homework better before buying… do you know if there are any third party (Google play store) apps that can do this? V annoying & wouldn’t have bought this tv if I’d known, I just wanted a smaller tv!
royabrown2
Hero
Duplicate - please ignore)
royabrown2
Hero
@LightFoot @Ruth-RSP
No - I imagined that Sony wouldn’t mix headings clearly saying ‘No’, like the one on Bravia Sync directly above Apple HomeKit, with ‘_’ marks the same size as dust particles (or worse) on the screen of this iPad.
Silly me 😠🥺🤪😢
Apologies to all affected, including those whose hopes were dashed (dashed - geddit?)
