Circles on my x95j
Ddaniels0509
Circles on my x95j
Hi all, my father has a x95j and in greys we can see circles all across the screen, at times this is incredibly distracting. It was bought with a 5 year warranty. Is this normal? Would this qualify for a replacement?
Any help would be appreciated.
6 REPLIES 6
LightFoot
Specialist
Hi @Ddaniels0509
You may struggle to persuade Sony to replace, but it is worth a try. I would contact Sony Support
What are those lights behind the TV? I could suggest a Factory Reset, but I doubt if it would make any difference.
LightFoot
Specialist
Hi @Ddaniels0509   Looking at your picture again, the large circles appear to be the bright lights behind the TV. It is not projecting the back panel onto the screen is it?
Ddaniels0509
Hi apologies for how slow I’ve been. It’s a govee t2 back light. Can confirm with it turned off the pattern is still on the screen
MaggieGreene
Community Team
Ddaniels0509
Hi @MaggieGreene i have yes and the issue has persisted
TheRealOG
Community Team
@Ddaniels0509
You'll need to contact Sony or the retailer whomever you have a warranty with and see what they can offer for you!
