CMU-BCI BRAVIA CAM
Willnort
CMU-BCI BRAVIA CAM
My television is a KD - 49XE9005. Just seen the blurb about the new BRAVIA CAM. Will it work on my TV?
LightFoot
Specialist
Hi @Willnort
I suspect that it only works on some 2022 TVs. Have a look at the page below as it lists the TVs it works on just over half way down.
https://www.sony.co.uk/electronics/televisions-remotes-selectors-cameras/cmu-bc1#pdp_slideshow_defau...
Note I have it bundled with my TV (XR-55A95K) and it certainly isn’t worth £199. Most of the features are still waiting for a future firmware update.
Willnort
Thanks for your input. From what you say, even if it was compatible it probably wouldn’t improve my television experience. I think the picture quality of my TV is superb. It’s just the sound quality that could be improved. I did try a sound bar once but I wasn’t impressed. I guess I’ll just have to keep wearing my hearing aides. Not for the volume. Just the sound quality.
