Colour temperature fault KDL-50W805C, Optical light fault
profile.country.BR.title
sonyfan0012
1. TV goes off with right colour temperature  Expert 1
I turn it off , and, after 8 minutes I turn on the TV... It's gone, it's all bluish.
I have to manually change it in the menu or change to:
Another HDMI
TV
App.
Did two factory resets and I won't do no more!
This is incredible. It's a basic thing. The TV has to retain its color
Configuration. I've never seen anything like this in my entire life!
2. The red optical light of the toslink connector for audio on the back of the TV doesn't go off.
I am just wondering if this nice piece of engineering is always online...
Can anyone confirm to me that, after 8 minutes off, the red toslink light goes off on the back of the TV, please?
Thank you.
91 REPLIES 91
sonyfan0012
this is bad, you should not do that. you gonna hurt your tv...
sonyw805c
who says this?? Do you have a link?
i do unplug my devices  over 10 years now, no probs at all.
as i said it´s only a work around... main problem(= doesn´t save picture colour temp) still is unsolved!
Make SONY Great Again
sonyfan0012
thank you for the work around.
but this is 2017. no buttons.
thanks for trying to help anyway.
sony needs to solve this.
Virus-free.
www.avast.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
sonyw805c
i´m 100% with you - this work around is good for a quick laugh
and this
sony has to solve that.
Phil9322
Maybe a more convenient workaround would be to switch to the home menu before turning the tv off?
profile.country.AT.title
Kuschelmonschter
Hero
Now, when turning on the TV, I had the problem that picture mode was set to Standard instead of Cinema Home... so annoyed by this TV...
sonyfan0012
Unfortunately neither of the folks at home would remember/care to do that.
sonyw805c
so let me ask the question 🙂
Did Sony solved the colour temp problem with the update
Release Date
  • 19-04-2017
for the w80xc series??
sonyfan0012
Don't know. There is a mention of a fix for a "auto picture mode" issue,
but i don't know if
it's about what we are experiencing.
Will you guys download to try?
sonyw805c
i?  hesitate  :slight_smile:
