The message you are trying to access is permanently deleted.
Hi All,
Is there a compatible webcam that works on my KD-43XD8099 model android TV, so I can use it
with Tellybean.
Thanks in advance
Hi @daveP_uk
The only Sony product I'm aware of is the CMU-BR100 which was developed for use with Skype for TV. There is still a support page for the accessory, but it could be that since support for Skype was discontinued the product is no longer being sold via Sony outlets; however, you might find one via third-party retailers.
Is there any reason why you wouldn't just use your smartphone or laptop/tablet?
Mick
