The message you are trying to access is permanently deleted.
Hey there,
Is it possible to change the "sensitivity" of the battery low notification? I'm using standard batteries with the remote and the notification seems to appear really early into their lifetime.
For example, we've had the notification popping up for over a month now, and the batteries are still going strong. I feel it would cause even more e-waste if I were to replace them every time the TV told me they were low.
Just get rechargeable batteries and charge them up overnight. It's a lot more eco if that's what you are bothered about.
