Did iPlayer disappear?
I have a KD-55X9305C Android telly.
The other day I thought I would try to use iPlayer on it, but the iPlayer option(app?) seems to have disappeared. (I usually watch iPlayer via my connected Freesat box or disc player.)
I'm pretty sure that there used to be a way of watching iPlayer directly on the TV. Am I dreaming?
(I found the iPlayer logo in the YouView app, but that makes me go into some strange, pointless tuning ritual which never finds anything - unsurprising as there is no aerial connected!)
Hi there
Try a reboot of the TV - Press and hold the power button on the TVs remote control for 6+ seconds and a message will appear on the screen saying it will now reboot.
Also, ensure that your TV is connected to your network and internet.
Hi there
Thank you. iPlayer is back.
