Difficulty in the setting up, sound from sound bars, picture, connectivity, etc, etc.
LawrenceYallop
4 REPLIES 4
IamNic
Hi @LawrenceYallop,
in order that anybody can help you, it would be nice if you could share additional details on which devices you are referring to.
- Nic
LawrenceYallop
Sony HT-SF150 Soundbar connected to Sony KD55XE9005 4K TV
LawrenceYallop
When I tried to connect my Sony HT-SF150 Soundbar to my Sony KD55XE9005 4K TV  HDMI Arc input using an HDMI cable I couldn't receive any sound, I don't know if I need an HDMI cable with Arc capabilities or any HDMI cable will do the job, instead I used the supplied digital optical cable, which worked perfectly.
IamNic
Hi @LawrenceYallop,
for ARC you need a sepcial HDMI-cable which supports ARC.
- Nic
