Digital Tunning on KD93
sukmudha7
Hi there,
I have two cables running from my Sky UK dish which I have attached to the MAIN and SUB connectors.  When I perform a digital scan no services are being picked up.  Can anyone help?
4 REPLIES 4
Hi there
Assumingly you've missed something somewhere in the process, try following these instructions:
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/69211/
sukmudha7
Managed to tune the Satelite, but nothing for Youview.  Does it use the Sky dish or the RF?
profile.country.GR.title
MiCal1967
Hi
Are you using two Satellite dish? As you say you have connected on MAIN and SUB. This kind of connection is for Twin sat tuner operation.
I think that YouView in UK uses the Antenna input.
sukmudha7
Hi there,
I have a octa LNB so have 2 sat cables plugging into the TV.  Looks like a aerial is needed for YouView 😞
https://community.sony.co.uk/t5/android-tv/youview-setup-without-an-aerial/td-p/2050935
