Dolby Atmos KD-70XF8305
walsh441
Hello
I would like to play Dolby Atmos via HDMI/ARC on KD-70XF8305.
When I use NETFLIX on TV, Dolby Atmos is present on my Yamaha RX-V583.
But when i use Android Kodi or VLC (from GooglePlay) to play video from USB HDD, then on my receiver is only DolbyDigital.
Is any option to fix it ?
Pascale_F
Moderator
Hi walsh441,
Welcome to the community.
I'll see if I can find some advice for you about this. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Almou_10
Specialist
Hi walsh441,
I've looked up the sound processing for this TV and found only the following: Dolby™ Digital, Dolby™ Digital Plus, Dolby™ Pulse.
So i guess it doesn't support Dolby Atmos.
Cheers,
Almou_10
