Dolby Vision Game Mode
samalik
Xbox just enabled Dolby Vision for games last week, but whilst my XH95 supports Dolby Vision, it only offers Light or Dark settings, no Game Mode.
As a result, the input lag is pretty bad and games are unplayable in Dolby Vision, is there any chance of a Dolby Vision Game Mode being added to Sony TVs via a firmware update?
TopBananaSr
A bit frustrating when you hear LG are storming away with DV 120hz. I'd be happy if they sorted DV with 60hz at least.
TopBananaSr
SkyNet404
Specialist
Hey,
If you check this link: https://www.sony.co.uk/electronics/support/articles/00254857
It says that the XH95 only supports eARC, not 4K120FPS.
But, if your TV does support 4K120FPS, then when you change the signal format there should be ''Enhanced'' and ''Enhanced Dolby Vision'', and after some digging it seems that 4K120FPS doesn't work with Dolby Vision sadly, so you gotta choose.
Cheers.
