hello i have a sony bravia kd55xe9305 and im wondering if i use the us firmware to download the dolby vision update would this work on my uk tv or would i lose the youview app etc? any help would be greatly appriceated im to impatient to check out dolby vision on netflix etc to wait
It makes no difference to the sound .its a souce issue.so therefore the sonus would be affected the same if you see what i mean....ie:the sound drops on the app that is being used not toe speaker system..
@miblogg39wrote:I keep the sound down to zero and just have sound running through a sonos playbar and 2x sonos plays 1s A’s surround .... it’s great for sport ... the 65 a1 is a fab tv just need this vision sorted !!
Ah ok .... didn’t realise that ... thanks for info .... will have just to Wait for update then via hdmi ... if it ever happens 😩
@miblogg39wrote:Ah ok .... didn’t realise that ... thanks for info .... will have just to Wait for update then via hdmi ... if it ever happens 😩
Hey no worries (the update will come via the network either wired or wireless not the HDMI .
Thank you much appreciated...
I see that the DV firmware for the XE9305 is starting to appear in the UK. I also see that a number of people have had problems with it - think I'll wait for it to arrive naturally with me rather than rushing things!
Anyway, does this update allow DV from external, HDMI sources? Or only from the built-in apps?
Ta
Not sure on the HDMI as got nothing to test it with as yet..
@StoufferTheCatwrote:I see that the DV firmware for the XE9305 is starting to appear in the UK. I also see that a number of people have had problems with it - think I'll wait for it to arrive naturally with me rather than rushing things!
Ta
It works over HDMi as well.
I have just tested my 65 A1 with the 4K Apple TV, and Dolby Vision works fine....
How did you download Dolby vision ?did you use usb ? Or have you received the update now .
I downloaded the update from Sony support site and manually updated via USB stick.
The download for the 65A1 is here
Think I will wait for DV to update automatically, tried side loading via USB but TV would not even find USB, maybe for the best after reading the problems.
My reply is about your Sonos soundbar and 2 x play 1`s set-up.
I have 2 x play 1`s and trying to justify to the misses spending another £600 for a soundbase / bar to pair up with the 1`s, is it really a good sound / noticeable difference / worth the money ?
NewtonsFlux
