DTS passhtrough bug on XH90/X900H on v6.1288
profile.country.HU.title
kfkrisz
A would like to report a bug. After the recent v6.1288 update when I try to use PLEX the DTS passthrough is bugged. It sends bad audio signal that crackles. I've tried with another app and the result is same. The only fix is set Digital audio out Auto 1 to Auto 2. Could you please investigate? Factory reset did not solved this problem.
Tags (1)
LightFoot
Specialist
Hi @kfkrisz   It is probably best to contact Sony Support direct for your country or region. I’m afraid that nobody is going to investigate on the back of a post in this community of customers.
