External keyboard Sony Bravia TV
grasmere11
How do I connect to model kd43xf8796 bravia
Hi there,
Which keyboard are you using?
Best wishes,
M
grasmere11
Sorry. That is part of the problem not sure what keyboard to use
dutchice
Hi @grasmere11,
Welcome to Sony Community! Try reading this article where you can learn more about connecting mice and keyboards to Sony Android TVs. You can find a link there too which should take you to a list of certified products that work with your TV.
Also note that you could install the "Video & TV SideView" app by Sony on a mobile device which will give you full control of the TV including the ability to use your mobile device for input as a mouse and keyboard to the TV. Both your mobile device and the TV will need to be connected to the same home network.
Cheers,
Dutchice
