Firmware v6.6555 now available in the UK
Ryanm1701
Just downloaded and installed via USB. no issues after installation.
From Sony Support site
Benefits and Improvements from the latest update
  • Improves the TV’s responsiveness when switching on from standby
22 REPLIES 22
Palexr
Any thoughts to report? Does it improve the TV’s responsiveness when switching on from standby? Or anything else for that matter?
davidpow
Thanks. I just saw this availability on MySony. Since installing the previous version (6.6545) i have had the issue of the TV going through its boot sequence after being in standby for a while. Is it safe to assume that his is what they are referencing here and it is fixed by this release?
Just checking before installing...in case it doesn't fix that problem and introduces a new one!
thanks again!
rooobb
Who better than you can assess it? :wink:
davidpow
Fair comment...I was just hoping someone might have tried it already and seen the problem fixed (or not!). I will try later (though the TV is quite busy while we are in "lock down" 😉
rooobb
In any case, even if someone else say that it fixes it, you are not assured it solves your specific configuration. In any case you may still want to wait other comments related to the general behaviour of the update
MrBrianPotter
I updated mine yesterday via usb stick and unfortunately my boot problem is still there when starting from standby after a few hours! I also have a amber led light now instead of the white one 🤔 I am also using a Sonos beam connected to the ARC slot.
davidpow
Same for me. KD55AG8 and the problem remains. Did factory reset after install but no good.
Come on Sony!
Sent from my iPhone
MrBrianPotter
Sorry forgot to mention I’m using a
KD-55XF8796 😐
LGSAMy
Strange, amber usually means the off timer is set or a recording timer .
