Hello, how to disable the screensaver on this TV? There is no option to choose from. Below I am sending images from the configuration.
Where is "Off" option? Or "Never start" ?
Solved! Go to Solution.
Hi @osterek,
Welcome to the Sony Online Community! To prevent the TV from entering into screen saver mode follow these steps:
Your TV won't enter screen saver mode, effectively bypassing the settings in your screenshots. If by any chance you would want to deactivate the Developer Options from appearing in the Settings menu you will be required to simply disbale the option under [HOME] > [Settings] > [Developer options] > [Enable Developer options].
Hope you find that useful.
Cheers,
Dutchice
Hi @osterek,
Cheers,
Dutchice
Hello @dutchice
Thank you for providing a solution to this problem. This workaround works very well. I'm surprised that this option is not in the standard menu functions.
You’re most welcome. We are here for you, so don’t hesitate to post your comments or questions at anytime.
Cheers,
Dutchice
How would you get to these settings without the remote?
