Google assistant cannot turn off TV
pritchmc
Google assistant on the TV seems to turn on the TV without any problems and works to change channel, volume etc but when trying to turn off the TV it accepts the command and then does nothing...
Any ideas or help? TV is brand new and is running latest firmware
Joe_Dohn
Specialist
What model TV do you have and what is the software version you currently have on it?
