HBO
profile.country.RO.title
Sorin2002
HBO
Does anyone know how to install?
Sony kd 43xe7005
România
4 REPLIES 4
Pascale_F
Moderator
Hi Sorin2002,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
Tenneen9000
Hi Sorin2002,
This TV doesn't have an app store to install 3rd party apps. I'd recommend connecting an external device via HDMI that supports installing apps from the play store to enjoy HBO on your TV.
Cheers,
Tenneen9000
Sorin2002
Only with HDMI?or you can with a stick to?i mean to download the HBO go apk for android and put it on a stick
Tenneen9000
Hi again,
That would require the TV to have an Android TV OS. This one isn't sadly, so side loading the app apk won't work.
All the best,
Tenneen9000
