HDMI from computer to Sony Bravia KD-65XE9005
profile.country.SE.title
Ehlern
Can not get a picture on the TV with a HDMI cabel from computer..i´m i missing something here?
From graphic card to hdmi 4 ..black picture. In Nvidia controlpanel it find Sony,but nothing happens.
Sean_Mc
Moderator
Hi there,
Can you let me know if you're using a High Speed HDMI?
Cheers,
Sean Mc
dutchice
Hi @Ehlern,
I suppose the computer is running Windows 10 and it works just fine with a different TV? There might be many reasons for your problem. But let's first try the following:
  1. While your computer is connected to the TV press and hold the WINDOWS key on your keyboard. Its the key between Ctrl and Alt.
  2. While holding the WINDOWS key hit the P key once. Then let go of the WINDOWS key.
  3. Wait for about 10-15 seconds.
  4. If you don't get a picture then repeat steps 1 to 3.
  5. Repeat steps 1 to 4 at least 4 times.
If you still don't have a picture post back here and we will try something different. Make at least sure that you have tried different HDMI cables and the different HDMI inputs on the TV.
Cheers,
Dutchice
