Hdr not working SONY KD75XD8505BAEP
Keisari55
Hi!
I have SONY KD75XD8505BAEP 75" 4K UHD SMART TV
When I bought this TV the description says it has HDR
I tried to use hdr on my ps5. Cant get in on 😞
I have good new HDMI cable.
Can you tell me where is the problem?
Thank you
6 REPLIES 6
rooobb
It depends what you want to pass to it, it doesn't support 4k@120 fps HDR input regardless of the cable
Keisari55
So this tv doesnt support hdr?
rooobb
I didn't write that, and you can easily check on YouTube if it support hdr
Keisari55
Okey, thak you!
Keisari55
HDR works now, I found the problem.
Thank you rooobb !
rooobb
If you can, share the problem/solution here so that it can help other with the same set up :wink:
