Help. Have a KD 43XG7093 connected to a Freesat record O.K.ALSO Need TO TUNE IN ROOF AERIAL HOW.
Gownorm
5 REPLIES 5
Pascale_F
Moderator
Hi Gownorm,
Welcome to the community.
I'll see if I can find anything out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Gownorm,
Is the aerial connected directly to the TV?
Cheers,
The_Black_Rose
Gownorm
Have done basic check of all wiring. Still need HELP TO SORT OUT TUNING PROBLEM
Gownorm
Help to sort out how to tune this t v  using roof aerial.l have no problem using the freesat box
LightFoot
Specialist
Hi @Gownorm   What exactly is preventing you from tuning in the terrestrial channels? You should note that you have asked for help in the Android TV community but your TV is not an Android TV. The menu steps for tuning in terrestrial channels is completely different for Linux TVs.
