How can I stop the hdmi & audio screen message.....KD-XG658096
Dash1st
I was hoping that someone might be able to tell me how I stop my tv telling me which HDMI I'm connected to & what my screen resolution is, as it seems to come on everyone a scene changes from dark to light, or visa versa. I took a quick photo to show you the message I'm talking about. I'm hoping someone will tell me what I'm not doing, or what I need to change in the settings.
Your help is very gratefully appreciated.
rooobb
Disable the info banner in the digital channel setup. It will stop any info banner.
rooobb
Dash1st
@rooobb Thank you so much, you are a star & your help is very much appreciated.👍
I can't believe it was as easy as that.
Thanks again 👍
rooobb
@Dash1st it is not so intuitive being in the channel setup :wink: ... anyway I'm glad you are now happy
