how to save fav's in kodi
fether
hi all im in kodi and trying to save some films to favarites but witch button on the remote is it ?? on my other android box there is a button with 3 lines on it that you press to put sub menu up to add to fav;s but cant see any on the remote can any 1 help
kind regards
fether
fether
ok iv sorted it i needed to use a usb keyboard and press c :wink:
regards
fether
fether
regards
fether
Drewde
Administrator
Thanks for letting us know you've solved it. :thumbsup:
Mertsi1340
Another way of doing it is to install the "keymap editor" add-on in Kodi and then program your remote control. I assigned the "context menu" to the red button of the remote control and it works without a problem.
You can find some tutorial regarding Keymap Editor on Youtube.
