How to set up the "On timer" to turn on the TV with the last used input?
profile.country.IE.title
kommers
I have a Sony KD55X75WL and I need to set up the On timer to turn the TV on every day at the same time, but I need it to display the same screen that it was displaying when turned off (last used input).
Is that possible to do?
4 REPLIES 4
Thalamus.
Champion
Hi  Kommers,
welcome to the Sony User Community..
Hopefully the following info in this link should help..
kommers
Thanks for the answer, Thalamus.
That's what I've been doing, but the timer app doesn't have the option to add the Internet Browser or the last used input as an input option. It would be great if I could add it there.
Thalamus.
Champion
Ahh you didn’t mention that you wanted your last used input to be the browser, as you have discovered that isn’t an option..
kommers
Yeah, sorry if I wasn't clear.
I can manage to set the TV to turn on already on the browser (last used input), but then it would have to be manually turned off and then on again. Ideally, I would like to combine that with the timer app.
