Info banner keeps popping
lollypop11
I have just bought a new sony tv 49XE9005. I have connected apple tv 4 using a hdmi cable.
I am playing a movie on apple tv using an app called "infuse player". Each time I start or stop a movie or rewind/forward, i see an info banner popping up on the top of the screen showing hdmi 2.
I understand that this banner shows each time you change a source but how come it is showing every single time I play a movie or stop or rewind or forward? Is there no way disable this?
I have checked the software version; it says up to date. I have also checked that the tv is not in retail mode. I have also reset the tv but still this banner keeps popping up.
Any help please?
53 REPLIES 53
anandsony
I have kd-49x7000e, everytime I turn over the channel to another channel the tv's info bar comes up with the input , resoultion and time bar.
Turning off Info bar option is not available in the model.
Let me know if some one could help me to fix this issue as it is very annoying.
Thanks.
Kermit_the_Frog
I don't know why this has been flagged as solved. I have this model in Australia and the Info Banner option is not available here either.
Home > Settings > Channel Settings > Infobar > Off
Does not exist on the most recent KD-49X7000E software.
LightFoot
Specialist
Hi @Kermit_the_Frog. That is because you are in the wrong forum. The solution is for Android TVs in the Android forum and your TV is Linux.
salty319
sane with kd49xf7093 any ideas
JamesTV
Sony does not give solution. It was a very bad experience with support team. They purposed:
1. Press info button to make the popup disappear (I am not going to press the button twice per minute).
2. Disable info banner in menu (they should know my model does not give the option)
3. Connect another PC (I am not going to buy another PC, it is brand new and not cheap)
My purpose is (PC Windows 10 connected HDMI to TV KD-65XE7096😞
- Keep HDMI connected
- Go to Sound settings in Windows and disable sound output in TV (right click and disable).  Sound remains on PC.
- Output sound through headphones to speakers (not tried to send headphones output to TV but I think it should work)
Info popup disappeared. I know it is not a optimal solution but I prefer rather than the banner appearing twice every minute. Also purposed solution for removing info banner from those TV that have the option is a cosmetic solution.
Hope it can help to someone.
Bypass86
hello i have a sony bravia KD 49XE7005 and i cannot find the info bar option in menu can you help me
BTW its a non android tv
planetexpress3000
Same thing with an XF9005. It's obvious once you know. Stupid banner popped up with DVD layer changes and was quite annoying, so thanks!
mike1871
I have a KD43XG7003 connected to my pc & the annoying info banner keeps popping up whilst I'm on desktop.  The good thing is that it doesn't pop up whilst gaming, but would be nice if we could disable it all together.
I have my pc connected to the tv via a DP to HDMI & then HDMI to a sound receiver.
Audio to TV is disabled but still doesn't fix the problem.
LightFoot
Specialist
Hi @mike1871
Sorry you have posted in the Android TV community and the work-a-round for Android TVs is shown in the thread under Solution. You appear to have a Linux TV covered by the https://community.sony.co.uk/t5/other-tvs/bd-p/tv_en_1 community.
You should note that the info banner is appearing every time the audio format changes. A work-a-round for Linux TVs, although it will degrade your audio experience, is to fix the audio format to PCM or Normal. Sony are aware of the problem but have chosen to ignore customer complaints about this for several years!
SonyBraviaUK
Never had this until updating to V6.7140 a couple of weeks ago.
Using the solution suggested seems to have stopped it from keeping popping up.
