Infrared blocked
jobbybhoy
Infrared blocked
my sound bar blocks the ir sensor on my Bravia kdl 50w805c, is there a ir repeater or some way to fix this.
Hi there
There are many ir repeaters - search Amazon and read up to see which one best matches your requirements.
jobbybhoy
Thanks but what type suits Sony
Hi there
Ive not used one, so i cant recommend, so your best to do a little homework yourself.  Ive had a scan of Amazon, an d this seems good for £11
http://www.amazon.co.uk/Repeater-Infrared-Control-Extender-Receiver/dp/B00S4IB6PS/
One of the questions for this product is:
http://www.amazon.co.uk/forum/-/Tx2R4UXV7E4HA0Y/ref=ask_dp_dpmw_al_hza?asin=B00S4IB6PS
There are no 'recommended' ones. So, if you find one and it does the job, please post back as im sure it might help others.
