Input sources gone from Home Screen
profile.country.NL.title
Flashlab2
Since the latest update on my XD93 I have the problem that all input sources (HDMI, AV etc...) are gone from the Home Screen menu. They are not hidden in settings and ARC and the Sync menu still work.
Does anyone have this problem too or even better have a solution?
Flashlab2
I found out that it had to with uninstalling Sony Shelf through adb. Disabling the app through the app menu doesn't have this effect.
Sean_Mc
Moderator
Hi Flashlab2,
I would recommend a reset on your TV which should hopefully resolve the issue.  You can find more details on how to do this here.
Let me know if this works for you.
Cheers,
Sean Mc
Flashlab2
